305 or 350?
^^ The best way to find the number is to climb under your hood you may have to put your knee on a valve cover or fenderwell but make sure you can get over the engine,look down between the engine and firewall it's gonna be tight but thre should be enough room to see where the trans. and engine bolt together. This is where your number will be I'm almost sure i's on the right side when your facing the car. BTW a flashlight is a must. Happy Hunting
If you can't see the numbers, but you can feel them....take a piece of aluminum foil and do a rubbing over the numbers. That'll give you an embossed image of the numbers.
Also works well for making "imitation" coins!
^^^ lol! Kinda makes you wonder what left or right really is? Mabey what they want you to think is left is actually right, but then you turn around and it's all backwards!!! OMG!!!! I think it's a conspiracy to confuse the masses!!!!! Could this be the end of modern man?!?!
BTW pretty cool trick with the foil never thought of that one
