1991 camaro v6
1991 camaro v6
Right now I'm looking at a 1991 v6 camaro the guy claims it has a 700r4 that's been turned into the 4l60e my qusten is will this tranny bolt up to my 1987 camaro's 5.0. The guy is asking 500 for the whole car of I get I'm just going to part it out the and use some parts for my camaro
unless it truly is a 4l60e with a removable bellhousing, then it wont bolt up to the 305. the 3.1 uses a different bolt pattern. if you need a trans, just buy one or rebuild yours
But, if the dash isn't cracked, the weatherstripping in great condition, the pull down motor in good order then there might be $500 in parts
the tranny isn't the only reason. I was going to use the interior In my car then part out the rest on cl and make the money back also the guy said he had all the receipts from the motor being rebuilt and the transmission being turned into the 4l60e
Danger Danger Will Robinson
if he had the receipts and the thing has decent tires or interior then he could get over $500 for the parts and then sell the scrap to the junk yard for $40-$50
Well I called him he said the dash is cracked the inside isn't in that good of condition it mainly has stains on the carpet I got some more pics of it the car has slight front end damage
it had
new tires
new brakes
new battery
305 v8
tranny shifted but had a broken mount
clogged fuel filter
slight dent in the front nose which i later repaired
I could have replaced the filter and mount and driven it but instead restored it because it was for a project
I paid $500
now compare vehicles and if you go to the 3rd gen projects you will see my thread and the before pictures so decide for yourself
