1990 Camaro RS PCM/ECM location
where can i find the PCM/ECM i just got the VATS bypass Module from bakerelectronix. i need to the location so i can install this.
any help thanks |
passenger side footwell. there is a plastic panel, remove that. there is one bolt on the firewall that may be covered by the carpet. once thats out, it will be the shiny metal box on the right side
