1989 RS how to install new antenna
does anyone know how to install an antenna when i bought the car the plug that you plug into your cd player was cut so what all do i need to do? please help!
RE: 1989 RS how to install new antenna
Remove the plastic fender liner. remove the antenna mast and you need an antenna nut socket or being careful not to slip or pinch your hands, needle nose pliers to remove the nut with the four notches that was under the antenna mast. from inside the fender there is a bolt on a bracket that needs to be removed.
Inside the car remove the cover under the passanger side of the dash. and if you are lucky the antenna wire is still there you can attach a piece of wire or string to pull through while you remove the rest of the antenna from inside the fender. Use the string to atttach to the new antenna to pull the wire through and fish it around to the deck. Happy fishing |
