1988 fuel injected 350-carb question
No, its still going to be upset with you, but as long as you everything correctly it will run correctly and you can still use the computer for the transmission, and other non-FI things. Just don't hack it up.
I just switched my 91 rs from EFI to carb. other than getting an intake, carb, and distributor your going to have to drop the gas tank get rid of the electric fuel pump and replace it with about a foot of fuel line. You will also need to get a fuel pump that mounts onto the side of the block. (which I did because I hate in-tank fuel pumps) Then for the sake of then engine looking clean your gonna have to clip all of the extra wires. But if the EFI setup works good in your car I would not suggest switching it, the only reason I switched mine around was because most of the wiring harness was bad and I couldnt get power to the fuel pump.
