1986 Camaro Iroc TPI 5.0 Problem
Old Feb 26, 2007 | 09:27 PM
smby101's Avatar
Default 1986 Camaro Iroc TPI 5.0 Problem
I have changed out my fuel pump. I tested the new fuel pump and know it will work. when it is hooked up to the car it has no power. There is no power to the fuel pump relay also and the service engine light does not come on when you turn the ignition to the on position. Here is the kicker. The fuel pump fuse is not blown. I have even changed it out and nothing still works. Any clues if this is the ECM possibly? I know there is not a fuse link per the wiring diagram.
Old Feb 26, 2007 | 11:53 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default RE: 1986 Camaro Iroc TPI 5.0 Problem
i have the same year and model, and i think mine had the same problem. the power to my fuel pump is directly to the battery, but its still on a relay and on the ignition. id run a new wire to the fuse from the fuel pump and see how that goes
Old Feb 27, 2007 | 03:26 AM
FlufyTiger's Avatar
What's the source for the diagram?
Old Feb 27, 2007 | 04:06 AM
MadMikeZ28's Avatar
Did you check the ECM fuse? Is the ECM plugged in? Check for power to the fuse. The light could be burned out. There may also be a light driver. A small blue box with a printed circuit board inside. Never seen one go bad but could be.
Old Feb 27, 2007 | 09:53 PM
smby101's Avatar
MIKE, IS THE ECM FUSE ON THE REGULAR FUSE BLOCK? IF IT IS I HAVE CHECKED ALL THE FUSES AND THEY ARE WORKING. EVEN PULLED THEM OUT AND VISUALLY INSPECTED THEM
bluesmoke662
82-92 V8 Tech
Aug 7, 2011 08:09 AM
person
Jun 28, 2010 10:02 PM
ryante
May 15, 2010 06:52 PM
Curt35
Mar 25, 2009 01:51 PM
smby101
Mar 2, 2007 12:49 AM
