Wire harness
What kind of a problem? Just not turning over, or not engaging? Check your wiring diagram for the EZ harness and see what color it says is the starter wire. There are two terminals, so be sure it's on the right one. You wont hurt anything if it's wrong, just move it to the other terminal and try again. Might also pull the wire off and hook a test light to it and ground, then turn the key and see if it's getting power when you turn the key to start position.
