Rebuild or replace (engine) + trans question
Old Oct 21, 2022 | 04:05 PM
PIFPrime's Avatar
Default Rebuild or replace (engine) + trans question
Hi guys,
I recently bought a 1981 Camaro and it "runs" I've put some $$ into it to get it running well enough to move around and hop to a shop and back. Not something I'd trust to take on a highway or any sort of distance. It's puking oil out of every possible location (both engine and trans).
I'm at the point where I need to decide if its less complicated and makes more sense financially to ditch the 305 thats rusty, leaky and doesn't run the best to a cleaned up 350/355/383 if I can find one cheap enough and a rebuilt trans.
What does everyone think? The stock 305 is caked in surface rust and oil and limping along. Do I spend to rebuild or replace? I can't afford new - I am raffling this car off next summer so I need to do things as budget as possible.
Lastly, I thought my 81 came with a 350TH transmission but someone (in a parking lot so with a grain of salt) said it came with something else and the 350TH was third gen (82-92)? What transmission is in it most likely? It shifts fine just leaks. If it's a TH350, I'd probably refurbish it and keep it.
Thanks and looking forward to your thoughts,
Jordan
Old Oct 21, 2022 | 06:43 PM
That 305 is a boat anchor,toss it overboard mate.
They're not worth rebuilding and the trans is likely a T-200 a lighter version of the T-350 and not as strong.
It will be okay with a stock 350 but if you buy or build a motor with some power you'll want to upgrade that as well.
I have a '75 350 from a pickup and a T-350 still bolted up to it.
It ran when pulled but the motor is stuck from years of sitting,probably rusted up but it would be a good core for a rebuilt.
It's still hooked to a T-350 trans that worked when pulled,I'd give them to you free if you're nearby.
Old Nov 4, 2022 | 03:23 PM
PIFPrime's Avatar
Hey Thanks for the reply! For some reason I didn't see a notification in my email.
I'm up in Northern Ontario Canada but I do appreciate the offer! I agree and I'm going to take your advice, I think I am just going to donate it to a mechanic school once I find a suitable replacement.
Old Nov 4, 2022 | 05:23 PM
Wink
Well good luck,shouldn't be hard to find a 350 they made millions of them.
Old Nov 27, 2022 | 06:21 PM
PIFPrime's Avatar
Deciding to go LS swap. Searching for parts now. Man Canada is so much more expensive than the States. I live near the border but its basically Rural America so I am going to have to figure out how to ship to somewhere near the border where I can drive over to grab things. I need a ton of parts and you guys in the south have things for like half price haha.
Old Nov 27, 2022 | 06:50 PM
Deciding to go LS swap. .
Well the LS is a great engine design,it'll be a lot more work but a sweet setup when finished up.
Maybe you can find a donor car '98-'02 Z28 up there that runs good but raggedy otherwise and save big then just get the swap kit parts here in the USA.
Good luck and keep us posted.
T1264rk
Dec 26, 2017 06:14 AM
WatsonCustoms
Apr 21, 2012 09:33 PM
81Z28restore
Oct 24, 2011 08:58 PM
acmech13
Feb 20, 2009 06:32 PM
Pro_built7
Apr 6, 2007 11:03 PM
