Need some recommendations
I've got a 1978 camaro that i'm working on currently. Running a 350/V8 with a TH350, but want to convert to a manual. What types of maual trannies can i run with this????
Some people go for the T-5 from 3rd gen Camaros if you aren't going to hotrod it, or the T56 from 4th gen Camaros if you want more strength than the T5. Both require some extra work to fit, move the crossmember, and adapt the clutch setup.
