Harmonic Balancer wont go on
Ok, then the key wouldn't be walking on you. Speaking of the timing chain gear, it is fully seated on the crank? Where in relation to the outer edge of the damper is the end of the crank when it stops?
That's what I'm wondering. With the damper off, take a small long screwdriver (or a stiff wire) and push it in against the gear. Make a mark on it where the end of the crank is. Then compare that length to how long the hub on the damper is.
