Camaro 69 |
04-11-2012 08:19 AM |
Sure sounds like very low rear gears to me. If you have a LSD/Posi rearend, jack both tires off the ground, spin one wheel 1 full revolution, and count how many times the driveshaft turns. If you have an open diff, jack only one wheel off the ground, spin the tire 2 full revolutions, and count how many times the driveshaft spins. As an example, if the driveshaft spins approximately 4 times, you have 4:10 gears, etc. I'm betting you have more like 5:13's in there. Also, your relationship between speed and rpm's is assuming the speedo has been calibrated for your gears. Without changing the speedo gear, low rear gears like that is going to make the speedo read way high, so it must have been "fixed".
