Second Gen Camaro Rear Sway Bar Frame Mounts
I just picked up a WS6 sway bar set out of a 1980 Trans Am, but I don't have the things to bolt it up with. I need the sway bar mount for the spring pad and the frame rail. I am pretty sure I can get the spring pad one along with the bushings simply from Autozone.
This is what I am missing I think. http://i2.photobucket.com/albums/y20...r/IMG_3021.jpg And these, but it looks like they come with the bushings. http://i2.photobucket.com/albums/y20...r/IMG_3019.jpg It would appear that this is everything. http://i2.photobucket.com/albums/y20...r/IMG_3027.jpg |
I use a Herb Adams/ Moroso sway bar mount on my 1979 Z-28 RS pro-touring bar. And I use a 7/8 rear bar.These are stronger I broke the original mount and rear 3/4 swaybar on mine:Can you say 500 HP) and use a front bar bushing. I use a grease able poly bushing,
Originally Posted by Zspoiler
(Post 674541)
