Changing Front Springs
Old Nov 22, 2022 | 03:28 PM
petreussg's Avatar
Default Changing Front Springs
Hello,
I'm about to start the project of a full suspension upgrade and have questions about removing and installing front springs.
After watching videos it looks like the front springs can be removed by placing a jack under the control arm and slowly lowering it so that it looses all of it's tension. Then to install you will need to use a spring compressor to get it compressed to a height to be able to install.
Is this correct? If so, what spring compressor is needed? What safety precautions should be taken?
Thanks!
1976 Camaro
Old Nov 22, 2022 | 07:16 PM
You should be able to rent a spring compressor at NAPA and they should know what you need for your car.
Old Nov 26, 2022 | 12:32 PM
manicmechanic007's Avatar
You will find both procedures are helpful and necessary
2 big line up punches a good jack and a spring compressor
You will find that spring real tough to compress
On the Camaros and Mustangs I use strut style compressors (outside type)
Get it started then install the inner Camaro style compressor in the spring and assemble with the floor jack and the line up punches
Good luck
Old Jun 26, 2023 | 09:40 PM
petreussg's Avatar
Thanks everyone. I got them changed a while ago just forgot to check back here.
I saw a bunch of videos of people just lowering the control arm and taking the stock spring out. I was not able to do that. I needed to compress the spring to remove, and then compress the new spring to install. I also needed a crowbar to pop the new spring into its grove.
Jr. Mechanic
May 6, 2010 07:07 PM
Leeet
Nov 24, 2009 11:26 PM
Bwalker
70-81 V8 Tech
Aug 25, 2009 09:41 PM
RaZoR
Oct 9, 2007 07:34 PM
amador123
Jan 13, 2006 12:57 PM
