back end
I could lower the air press but then the tires rub. The previous owner thought it would be cool to put 15x10 reverse offset Cragars w/ 255/60's on the rear. the air shocks make that possible. It looks cocky but the car was designed to be a cruiser now it rides like a tank. Keep in mind that when you change the cars stance ie: raising the rear, you also change your front end alighnment. If anyones interested here's the specs that camaro's like to be set to:2 deg caster w/ .25 deg stagger .2 neg.camber. the factory specs suck 1 deg caster and .6 deg pos camber drives like sht don't let your alighnment shop set your camaro to these specs.
HEY V8CHVYGUY I'M GLAD I CAME HERE, I INSTALLED SIZE60 TIRES IN THE REAR AND I CAN'T DRIVE MY 68 THE QUARTER PANELS HIT WHEN I RUN INTO A SMALL BUMP ON THE STREET, PLEASE HELP. I DO HAVE NEW KYB SHOCKS
