Is the 1974 Z28 suspension different than the the standard coupe? If so what is different?
1971BB427
04-27-2014 09:43 PM
Originally Posted by Direct Camaro
(Post 689804)
Most Z28 models have HD suspension, or what is known as the F41 package. This includes a little heavier front and rear spring, plus front and rear swaybars, plus the front swaybar is a little heavier than the std. coupe, which doesn't have a stock rear swaybar.
Direct Camaro
04-28-2014 07:51 PM
Can you add a rear sway bar to the coupe?
1971BB427
04-29-2014 09:47 AM
(Post 689939)
Yes, you can add a rear swaybar. It's not a bolt in on the frame end, as Chevy didn't see fit to install the threaded fittings in the frame if it didn't have a factory swaybar. I've done a couple for friends using factory swaybars and mounts. It's easiest if you buy a nutsert tool and install the two threaded nutserts on each side for the frame mounting points. Harbor Freight sells a nutsert tool for about $20. It comes with an assortment of nutserts, but I'd buy the 4 3/8" nutserts you need form a good hardware store, as not sure I'd trust the Chinese nutserts for this application.
The axle mounting is just a bolt on, and easy. Once the swaybar is bolted up, you can mark the frame holes for brackets. Then drill the 4 holes, install the nutserts and bolt the brackets on. Pretty simple job, and a real improvement to handling.
Direct Camaro
04-30-2014 07:58 PM
Thanks . Sounds easy enough. It should help the car with handling. what are your thoughts?
