Th350 automatic trans.. Help need pics!
Here's a couple of pics on the shifter cable and bracket that mounts to the trans. The bracket gets bolted on with two of the pan bolts and there is a pin that holds the cable to the lever on the trans. No pics of the kickdown cable, sorry. That connects up on the intake with a bracket. I have a bracket that I wont be using anymore when I reinstall the new trans if you need one. Hope this helps, it's really only the bracket. Good luck!
Were you able to get anything figured out with the hookups? If you need other pics of anything let me know, I'll do my best to help out. I've got a kickdown bracket, if you need one, it's yours. Good luck, let us know how it's going!
