78 on my plate |
10-18-2013 08:23 PM |
Welcome to the forums! From what I've seen, Auto Metal Direct (AMD) for replacement panels is a good choice. Fitment is good and metal thickness is almost better than original. Also, I have been using Eastwood's Fast Etch for rust removal and it works really well. As you probably already know, there's a lot of different choices out there and plenty of opinions as to what works the best. From experience, I would choose the Fast Etch again if I needed more. Eastwood has a huge selection of different products if you haven't taken a look there. I've even made a molasses solution that completely removes rust if you've got the time to wait for it to work. Hope this helps. Best of luck finding something that works well for you.
