76 Fuzz buster
I'd just check it out to see if it's bad, then replace with the earlier style pump without a return line. Chevy used them for decades without a problem.
True, many older cars didn't have return style mechanical fuel pumps, but then we didn't have E-10/E-15 fuel either. The return at the pump was added to help solve vapor lock issues that some would get with our crappier gas in extreme heat conditions. Recirculating the gas keeps it cooler in the line, it doesn't heat it up. And if you have a gas perking issue at the carb due to heat, a restricted return right before the carb inlet can help alleviate that problem.
My heater box came in. As it turns out.
The hole in the fire wall is for the box with the ac. Its a rectangle cut up and down. The box I got is for the non-ac one. I wanted to ask if any one knows the measurements for the non-ac hole in the firewall. If nothing else, I'll weld up the hole thing and just start over.
Pics.
1 is what I have now.
2 is what I need.
Thanks
Pics.
2 is what I need.
Thanks
Pics.
2 is what I need.
Thanks
Pics.
2 is what I need.
Thanks
