How to change 76 Camaro power window motors
Old Oct 30, 2012 | 08:08 PM
bigdee's Avatar
Default How to change 76 Camaro power window motors
1976 Camaro LT
I have some new motors, but with the door panels removed it looks like the motors are rivited and inside the door bewteen the outer shell and the inner shell - way to much metal in the way to remove and install a new one. What am I missing - surely you don't have to cut some of the interior metal out?
Old Nov 1, 2012 | 01:33 AM
alho672's Avatar
u gotta cut the rivets out, then the motor will pull right out, use bolts to put it back, just done it on my 81
Old Nov 4, 2012 | 05:55 PM
BBrendal's Avatar
Is there any spring tension on the regulator? Ive heard stories of the regulaor being unde spring tension and it could take a finger off. I need to do the same on my 79. So is it as simple as drilling the rivits out and replacing or is the any cautions to be aware of?
Old Nov 5, 2012 | 11:11 AM
alho672's Avatar
no there is no springs, or tension on the motor, its pretty simple to change, when u take the rivets out the window tracks want to move out of plave a lil but when ur ready to put it all back together just take a screwdriver and stick back through the rivet holes and line it all back up and put ya bolts in
Old Nov 5, 2012 | 06:09 PM
BBrendal's Avatar
Cool! Thanks for the info!
Old Nov 5, 2012 | 11:14 PM
alho672's Avatar
no problem man
Tipsy
May 21, 2015 01:55 PM
Davescamaro93
Jun 27, 2011 05:23 PM
greenarrow
Mar 1, 2009 10:54 AM
eaglekeeper
Jun 14, 2008 01:23 PM
mofo123
Nov 1, 2005 11:49 PM
