woh all messed up..
Old Dec 20, 2009 | 10:03 PM
  #21
Gonna haul the whole driveshft down there with you?
Old Dec 20, 2009 | 10:33 PM
  #22
brownstone101's Avatar
na he will take my word for it. im in there every day. hes got a cool monza with a 327. ill just return the old one if i can get credit for it but yeah he knows me so it should be easy
Old Dec 21, 2009 | 08:49 PM
  #23
got new u joint today all went in perfect. fixed my shifter button today to. random but it went well. adjusted my shifter throw down below since it wasnt goin into park all the way. filled the trans up to spec. did a few other things. bled the breaks im on the home stretch.... gota get some pipe bent for exaust and then move to doin the hood. but other than that shes almost ready!
Old Dec 22, 2009 | 07:11 PM
  #24
http://www.youtube.com/watch?v=k4xNq...eature=channel
http://www.youtube.com/watch?v=qViZ8...eature=channel
http://www.youtube.com/watch?v=GCbYA...eature=channel
sorry about linking to another forum. but im a member on there and made a forum with all the pixs on it. i did my first test run today and it doent like open headers much or i thought 1,500RPMS was lift off lol. but heres the link to the forum with all the pixs. its in a good progression of how i worked though this. for anyone who wants to check it out. hope u guys enjoy it.
http://www.fbodyonline.com/forum/f14...-months-53551/
Old Dec 24, 2009 | 04:28 PM
  #25
ok so my car hesitates and has a slight popping miss sound around 2000RPMS and under load. i gaped the points to .016 and have it at 9 degrees BDC. im going to take it back to 4 and do another drive. but it does have a miss u can only feel while driving it. any ideas?
ok. so i figured it out. carb was setup retarded. back when it was installed and all blocked up with an air pump and all. the secondaries wouldnt open. so in an effort to help it out i removed the restrictor ball to try and get it to open. still wouldn't. whats happening is the car now has the right vacuum and the ball was out of the path so it was flopping the secondaries open when the load and vaccume was right. i replaced the ball and installed a lighter spring and had the same bog. so i replaced the stock spring and im going to give it a test drive tomorow but im sure it will fix this.
it explains why at 3K rpms it leans out while in neutral and pops because only the small primaries on my 600cf are fueling it up to that RPM. it got better the richer i made it so now i should be able to tune it right to the rpms that the secondaries start opening and let it help from there. i got a new diaphragm and spring kit to help me out so i will be doin a little tuning soon. but i think this is the main cause of my load bog. and miss.
Old Dec 26, 2009 | 08:20 PM
  #26
All those little details. I'm sure you'll work it out bit by bit.
Old Dec 26, 2009 | 10:23 PM
  #27
... im confused. i think my timing is wrong. is rotating the cap while the vac is unhooked the same as setting initial timing? or is initial timing setting it in a tooth back?.... im all confused now.. my vac guage says i have late timing but its set to 9 BDC with the vac unhooked..
Old Dec 26, 2009 | 10:56 PM
  #28
You have to disconnect the vacuum line to set timing, but be sure to plug the open line or your timing will be way off! Usually 4-8 degrees BTDC works, but depends on your compression, etc.
Old Dec 26, 2009 | 11:00 PM
  #29
... yeah. ok. so i plug the line with a cover and my timing mark is set at 10. gonna move it down to 7 tomorrow cause i hear thats a good sweet spot on 305s but i will still play with it. but that mark is correct initial timing. correct?
Old Dec 26, 2009 | 11:08 PM
  #30
Yea, stick a golf tee in the end of the line when you pull it off the vacuum advance. That's the only timing you can really check. Just set the timing with the line plugged. Then reinstall the line on the distributor and set the dwell angle with a dwell meter by turning the screw on your points, (if your distributor has points!).
