This is why POR 15 can shove it
I blasted my car down today. For those who don't know the previous owner blasted the bottom and coated it with this stuff. I used to think it would be a save all. Now I hate it. Here's why.
It literally came off the rocker panel in sheets. Not much adhesion here. I can get better adhesion from epoxy primer for less than half price.
Then there's the fact that my car has never been outside overnight since it was done. However long ago it was there is no excuse for rust like this. This is the trunk floor. I haven't even washed the car.
He said he blasted with sand then used marine clean. It could very well be his cleanliness that caused it. The stuff I put on hasn't moved but this stuffis almost 20yrs old. The rust is my biggest worry. Its on the trunk floor. Not an area that sees much water, specialy stored inside.
I was posting so others don't spend a ton on this stuff thinking its a cure all.
I'm not a fan of POR15 I have heard from some people that are in the business of restoring cars that POR15 is a isn't reliable if the conditions aren't right during application it's more of a liability using that stuff. Thats why I went with epoxy myself on my car.
I like Black Magic rust converter applied before the paint, if there's any reason to believe you didn't get all the rust off, or there may be hidden rust. It works great as a neutralizer, and I pour it into places where you just can't blast or clean, and on surfaces that are porous from rust pitting.
Edit: That should be Black Star rust converter!
I can't find in on Google except from the UK. Is this the correct stuff?
FLAG Paints Ltd Black Magic 1 Litre and 250ml Bonus Pot
I was going to be ordering some POR-15 so I'm glad I read this thread.
