-   70-81 General (https://camaroforums.com/forum/70-81-general-12/)
-   -   Where is reverse switch? (https://camaroforums.com/forum/70-81-general-12/where-reverse-switch-84061/)
Gene Machine Sep 8, 2019 05:18 PM
Hi all. I have a 1980 Z28, and the backup lamp won’t light up in reverse.
when I cycle through the floor shift, it comes on briefly before I get to reverse, then shuts off. So I am guessing that the switch is loose or out of alignment.
i took the center console out, but can’t find any electrical connection going to the PRNDL, other than the lamp.
Is there another switch somewhere?
craby Sep 8, 2019 09:56 PM
I think the auto is in the column, might try adjusting the shift linkage a little and see if that changes it. manual is on the trans.
Camaro 69 Sep 8, 2019 10:01 PM
Your reverse/neutral safety switch (one unit) is mounted at the base of the steering column, under the dash.
Gene Machine Sep 9, 2019 04:53 PM
Cool. Ok, thanks guys I’ll look under the column.
Zspoiler Sep 9, 2019 07:39 PM
Its on the column
