What part to choose.
Old 05-10-2007, 08:59 PM
dodge destroyer's Avatar
Default What part to choose.
Just wondering what you guys thought the next performance should be on my car
Old 05-10-2007, 09:09 PM
thebandit110's Avatar
Default RE: What part to choose.
hey man. i have a 79 an just put a 350 in it. i put an edelbrock high rise and a 650 performer carb on it. my next thing is def. the cam with roller lifters/ rockers. after that i will b pushin over 330 hp easy. so im fine with that. than im gunna take a break an do some body work for a while than after that im gunna change the heads completly and im gunna leave the fuel pump an just put a edelbrock performance pump... but hey the options are limit less .. so good luck brotha
Old 05-10-2007, 09:10 PM
oh i got the dynomax headers also. the black jack headers i belive they are called
Old 05-10-2007, 10:14 PM
Same ones hear couldent afford any crome or polished aluminum.
the thing with the lifters is I dont really want to buy the intake gaskit.I was gonna just go with the aluminum heads but being over $600 it's kinda hard to afford any thing.
How much Hp does the lifters give me.
Old 05-10-2007, 10:23 PM
well with replacing the heads. your still gunna need the intake gasket. and if your gunna do lifters you should change the cam also. that will give u more than just roller lifters alone. unless u got a nice performance cam shaft. and do the rockers also. u can get an entire kit from summit. im lookin for all the same stuff. so i sit on the john with my summit cataloge( i know, thats nasty. but my camaro has takin over my life) but that will all def. help for more hp on a budget.
Old 05-11-2007, 12:52 AM
74454bb's Avatar
May 2007 ROTM
Go with the MSD ignition, or Accel. That is cheaper and you won't have to take it to the shop to instal.
Old 05-11-2007, 10:58 AM
cbr600rx7's Avatar
I would run the MSD and Ignition first just because it’s a cheap weekend project. Question for the guys running the high rise. I am running one with my current 350 in my 79 with a street avenger carb and am having clearance problems there is no way for me to get a filter up there and close the hood. I have considered just buying a new cow hood but I kind of like the sleeper look. How did you clear it?
Old 05-11-2007, 11:11 AM
74454bb's Avatar
May 2007 ROTM
You can get one of the edelbrock triangle foam air cleaners, or a drop base air cleaner. http://www.jegs.com/webapp/wcs/store...10002_71910_-1 I have the holley powershot and it has a drop base, about a half inch heigher then the edelbrock filter. .......... This is the edelbrock, not great but works. http://www.jegs.com/webapp/wcs/store...43327_-1_11349
Old 05-11-2007, 11:46 AM
cbr600rx7's Avatar
74454bbYour my hero
Old 05-11-2007, 11:58 AM
74454bb's Avatar
May 2007 ROTM
Thanks, If you go with the holley powershot, and it doesnt have the drop base, let me know and I'll trade you bottoms.
Quick Reply: What part to choose.
