what to look for in a used rear end?
I found a 8.5" 10 bolt with 3.42 posi with drums and leaf springs locally for $200. It's the factory GM parts so what should I look for to make sure it would run good?
he also pulled the cover to check the gear ratio
Tough one, because if we have to tell you what to check, then we have to assume you'll know a good wear pattern from a bad one.
Check the gears for unusual wear patterns, scoring, chipped or damaged teeth. The ring and pinion gears come as a set. If one of them is damaged, out of specs, or worn both must be replaced. When a vehicle pulls a heavy load the pinion gear tends to ride on the outer portion of the ring gear. This will cause excessive scoring evident on the outer edges of the ring gear.
well he said it was supposed to be from a 81 Z 4 speed camaro so it would have 3.42's but it's only a 3.08 posi. it's alot better than my 2.56's that i have now but i don't know if I should just sell it or just use it for now
Considering the price I'd run it until the BBC is in, then decide if you want to change gears. Either way, I'd still keep it and use it.
![Big Grin](https://camaroforums.com/forum/images/smilies/biggrin.gif)
