Vinyl top molding??
Vinyl top molding??
I have a '78 Camaro. I don't think they came with vinyl tops. But I know the rear window was the same in '75 through '81 Camaro's and Firebird's. Some of them came with 1/2 and full vinyl tops.
My roof is rust pitted. It's not to bad where it can't be fixed. Honestly I'd really like to put a full vinyl top on it.
I'm having no problem at all finding the actual vinyl top. It's the molding that go's around the quarter panel and in between the rear window and trunk that I can't find. Anyone know where I can fine the molding?
Thanks, NYH1!
Thanks, NYH1!
Thanks, NYH1!
Thanks, NYH1!
If you have a pitted roof now, it will only get worse with a new vinyl top. Those little pits will trap condensation and be a area for future rusting. The temp changes under a vinyl top from hot to cold will naturally rust no matter what you do, unless you remove it every 8-10 yrs to restore.
I'm talking about the molding that starts at the door window on the quarter panel, runs horizontally around the back of the car between rear window molding and the trunk on the rear filer plate (I think they call it) and end at the same point on the other side of the car.
Mid 70's Firebirds were available with full vinyl tops. CLICK LINK and scroll down. That's the vinyl top I want and I need the side molding as you'll see.
That's the way my top was. No drip rails on the roof, and no different chrome anywhere except the divider chrome along the bottom edge of the top.
I can find 20 different places that sell the actual vinyl top covers anywhere from $110 to $175. I just can't find the molding/divider chrome anywhere. Do you know where I can get it? Or have it made?
