twin turbo's in a 305?
I heard from a buddy that the 305 was built like a tank he says it is possible to put twin turbo's in it and it wouldnt crack the block. my question is is it possible to do that or will it blow my engine faster. and if it works without blowing my engine what would i need to buy in order to put it into my camaro?
RE: twin turbo's in a 305?
305 go boom [:o]
Factory 305 bottom end it good to about 275HP (dependable).Youcanput two turbos on it but make sure you got a big waste gate and don't let the pressure above 2 or 3 lbs.I have repairs a lot of 305's that did not make out of their GM warranty with no turbo's. Yourbuddy is cluelessunless he was referring to a septic tank.
this is why people dont usually modify the 305, when the ford 302 is such a strong performer. the 305 is just weak, more economical
+ 1for the 302. 5.0's would be one stang id own parts are cheaper and body is lighter
