Tranny Won't Fit
Old 07-24-2010, 10:21 PM
Latinoeheat's Avatar
.....time to start decoding numbers so I can find out exactly what this tranny is then lol.
Old 07-25-2010, 06:15 AM
You should just continue with a 700r4 swap. There longer and need a shorter driver shaft and moving the crossmember back. But then you have OD.
Old 07-25-2010, 09:25 AM
So if it is a 350 your back to the original problem.
http://www.youtube.com/watch?v=vFFIPyv2C_4
Old 07-25-2010, 08:11 PM
Thanks for the video. Just a quick question, can I install a 350 lockup as I would a regular 350 without using the electrical lock up plug?
Old 07-28-2010, 09:16 PM
z28obsessed's Avatar
Also a lockup comverter will not work on a non lockup tranny, and vice versa...
Old 07-28-2010, 09:34 PM
cool, I've got all the info I need. I'll probably get the tranny put in early next week. I'll let you know how it goes.
Old 07-28-2010, 10:03 PM
patc makes a crossmember for the change. i still dont understand why the 700r4 would not bolt up unless he was trying to use a 350 lockup converter. 700r4 is a lockup converter as well. anyways good luck and hope it works out.
Old 07-28-2010, 10:29 PM
The trans is actually a lock up 350 with the proper lock up conveter. I had never dealt with a lock up trans before so the electric plug and kickdown threw me off. Bad info from a few people made me believe it was a 700r4. But the forum helped and it's all good now so I should have it bolted in early next week. Thanks
WIspartan1026
03-25-2010 09:58 PM
bhoeksema
03-06-2010 08:38 PM
blowncamaro
10-12-2009 09:05 PM
rancheronut
07-14-2009 01:12 AM
mpd228
05-11-2009 09:52 PM
Quick Reply: Tranny Won't Fit
