tranny for 600-800HP???
Old 07-09-2007 | 12:12 AM
70_boosted's Avatar
Default tranny for 600-800HP???
what tranny would you reccommend, or would the th350 i have do it?
Old 07-09-2007 | 12:29 AM
thebandit110's Avatar
Default RE: tranny for 600-800HP???
up grade to the turbo 400. and put a high performance converter. and valve body in it. shift kit and what not. or you could do the same for the turbo 350. but i like the 400.
Old 07-09-2007 | 04:26 PM
79maroman's Avatar
with those high of numbers, you would be better off putting money into a th-400, like bandit said. 350's are good, but the 400's are a little heavier duty.
Old 07-09-2007 | 07:09 PM
70_boosted's Avatar
just saw today that i indeed do have the 400...
Old 07-09-2007 | 09:10 PM
riceeater's Avatar
the 400 is great, but you could also look into a late-model or manual swap as well. I just did a bunch of motor work, an I am puttin in a stick cause they just seem to hold up better
Old 07-09-2007 | 10:00 PM
70_boosted's Avatar
i considered that, what kind of work would i be looking at having to be done in order to fita later model 5/6 speed?
Old 07-09-2007 | 10:17 PM
74454bb's Avatar
May 2007 ROTM
you would need a built up 400...I would stick with an auto if you planed on an auto in the first place...go to www.jegs.com ... and www.summitracing.com, order the free catalogs and check out the TCI auto transmissions.
Old 07-10-2007 | 05:22 PM
70_boosted's Avatar
hav ethe free mags already...i didnt plan on just an automatic, but how all around driveable can i make the 400 trans, i want it to hold the power but still be able to cruise
Old 07-10-2007 | 08:45 PM
riceeater's Avatar
Its ok, 1:1 final drive, so itll suck gas. with the late model swap youd have to beat on the tunnel some, an have the driveshaft shortened along with putting in pedals, so a couple weeks worth of work, but instructions are on the nastyz28 forum too.
Old 07-11-2007 | 12:28 AM
70_boosted's Avatar
yea i figured that much, ill have to research a little more just to see what is best for my entire set up, thanx for the info tho
Quick Reply: tranny for 600-800HP???
