too soon for synthetic?
Doing a compression test is useless at this point. As we said, it takes times and miles to break an engine in! Change it back to regular oil, and get the miles on it in varying speeds. Those rings wont be fully seated, so a compression test wont prove anything.
Every Year One power crate motor comes with a personalized dyno. Does that mean they are doing something wrong? I do not thing so. I have read alot of differing opinions on break in. Some people state to take it easy and break it in over 500 miles, some say run it hard right from the get go. This is from various engine builders I have spoken to. There isnt much consensus on this and I have read articles on both sides and both sides have good points. Hopefully you are fine, but I do not think the dyno had anything to do with it.
I've got friends who say they break an engine in "like I'm planning to run it". So their theory is if you're going to run it hard, then break it in the same way. I've never seen one of them broken in that way that wasn't an oil burner early in life.
ok i guess i will drain the synthetic oil and switch back to conventional before i drive the car again. i can save the synthetic that i will drain because it only has 20 miles on it right? would hate to waste $75 in oil. Hope the 20 miles i drove with the synthetic wont cause issues. yeah i will do a compression test later on i meant
As long as you drain the new (20 mile) oil into a clean container, you can reuse it. When re-bottling the oil, I would use a paint strainer in a funnel to make sure you don't get any dirt particles. You've already gone through the critical initial break-in, using conventional oil. Now you just need to drive the car to continue letting the rings seat in. Don't beat on the engine, but don't baby it either.
Yeah, I guess I'll try typing a little louder next time. That, and I'll type a little slower so they can catch up!!! lmao
