starter problems help!!!
ive got a 1976 camaro with a 383 stroker and i have the stock starter and a gear reduction starter. now the guy i bought it from said he started it with a regular starter and it blew teeth off the flywheel and the starter was deystroyed. when i got the camaro it had the stock starter in it intact and operational but he said to put the new starter in so i did but it doesnt fit correctly because when i go to start in the fan spins but it makes a grinding sound like the gears arent alining correct. so i looked again and the bolts dont take the starter flush against the block so i think it is chattering and moving and running into the flywheel instead of meshing with it. i put the orighinal starter back in and the bolts took it all the way down flush against the block but i havent tried starting it in fear of wrecking the flywheel and starter. which starter should i use???
