spot welding
Has anybody here tried to use a spot welder for attaching body panels , i'd like to try to spot weld as much as possible when i install new panels on back of car, or should i just mig it in ? i was thinking on buying cheap spot welder. I was looking to try to save some preptime by not haven to punch alot of holes andnot having togrinddown all the mig welds. thanks
RE: spot welding
Well if you cut the hole, you could use the mig welder to weld around it and it would semi look like a spot weld.
RE: spot welding
If you get a spot welder, I suggest you do a lot of practice on scrap metal before you go around burning holes in your car. Go to your local library and borrow a book on spot welding.
RE: spot welding
We had a spot welder in the body shop but the large jaws would not fit every where. We would use an easy grind wire (I think it had a high alloy content) and just a quick buzz with a rolox grinder with 40 grit and it was done. wire feed welds dont have to be huge if you do it right.
RE: spot welding
The few times I do it myself I have to do a mig. I can't weld wortha damn. But I've gota guy that has spot welded some of my mess and it turns out great. But I certaintly wouldn't want to try it.
RE: spot welding
thanks everyone ,i figured i'd have to mig weld [spot] in hard to get to areas. if i get some extra money ,i might buy a 230 volt spot welder , practice alot and read a book or two, if i get it i'll post pics using it. http://pg.photos.yahoo.com/ph/mac10p...illy/my_photos
