Speedometer drive gear ?
Old May 21, 2012 | 01:39 PM
riss1978z28's Avatar
Default Speedometer drive gear ?
I just got my speedometer hooked up and it is running about 30mph to fast. Do I need a drive gear with more or less teeth than the one I have now?
Thanks
Old May 21, 2012 | 02:27 PM
The ring gear on the output shaft (inside the housing) is the drive gear. The one your speedo cable connects to is the driven gear. To slow the speedo down, you need a larger (tooth count) driven gear, or a smaller drive gear. Or you may need to replace both to get the calibration right. Here's everything you may or may not have wanted to know about speedo gears: Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
manslaughter299
Jul 10, 2012 08:17 AM
Frankenstein
Nov 19, 2010 11:21 AM
Vet76te
Aug 22, 2010 07:46 AM
62rampsidekid
82-92 V6 Tech
Jun 26, 2010 04:01 PM
kyphur
Nov 11, 2007 05:27 PM
