seat belt pic please!
Ok can some please post a pic of how there drives seat belt is bolted up, i got the car sunday and cant figure it out, and kinda need it soon.
someone*
Sorry, I've got 5 point harnesses, not seat belts.:(
1 Attachment(s)
Look in my progress thread. I have just took pics of my floor pan. I can highlight the bolt holes for you. The super easy was is to look under the car and fing the big square plates that anchor them.
Ok just for you. Attachment 22220 |
thanks after i went out and looked i found it, the thing i had the problem with was where the retractor thing mounted, but i got it. just had to peal the headliner out a little bit, which is just carpet lol. but thanks for the pic. Also.. whats the bolt hole for thats at the top of the screen? i didnt use that one.
well, i also rigged mine, is that for the rectangle part that holds it down by your waste? cause i rigged that part,
Yeah,that is what that hole is for.
ya... i dont recommend "rigging" your seatbelt
^X2 Not a good idea at all, use the same mounting points and hardware that GM intended.
I believe thats the anchor for the third point. One up top one on the left (driver side) and the lock on the right. If it was two points your butt would side forward on impact. Maybe even go under it all together.
