saginaw numbers help?
ok, so the stamped numbers im guessing are supposed to be the same right? im getting what looks like 2 different numbers, both arent quite full punches. like they didnt get a good one on the first so they tried again. anyways first set of numbers on the flat spot are
2A7S52599
8A7532599 im guessing its a mix of the both of them. those are the stamped numbers, cast are
housing 3925656
tail 352254
cover 6261888
10 spline input shaft.
any info you guys could help me with would be great. ive searched on it already but didnt quite get what im looking for. guess theres supposed to be a shorter number but im not seeing anything else. theres a piece that looks like it maybe would have been that small section but it didnt come though on the casting.
2A7S52599
housing 3925656
tail 352254
cover 6261888
# of grooves 1st 2nd 3rd 4th Notes:
0 2.85 2.02 1.35 1.00
1 2.56 1.81 1.37 1.00 Third gear on cluster has 25 teeth
1 2.56 1.81 1.44 1.00 Third gear on cluster has 21 teeth
2 3.11 2.20 1.47 1.00
3 3.50 2.48 1.65 1.00
