Rust!!
Old 06-10-2011 | 11:14 PM
Jeepin's Avatar
Default Rust!! HOLES!!!! PICS!!!
okay so i took out the seats and carpet from my car and their was some rust not too much and i started grinding some of it down already!! i im going to use some rust converter like i seen someone else on this forum using! but i did run in to a problem when i was grinding the rust out there was some parts were there was small holes not too big....is this a big concern or should i just keep going?????
Attached Thumbnails Rust!!-photo.jpg   Rust!!-photo-1-.jpg   Rust!!-photo-2-.jpg   Rust!!-photo-3-.jpg   Rust!!-photo-4-.jpg
Old 06-23-2011 | 06:13 AM
Ratt042's Avatar
Trail and error my freind ..... Trail and error! lol only advice I got
Old 06-23-2011 | 08:40 AM
80ZJoe's Avatar
July 2010 ROTM
I would be concerned, rust is like cancer if not treated it could spread. I would just cut the holes out and do little patch weld jobs and for the smaller holes i would fill them with little weld beads or you could always fill it in (fiber glass resin, seam sealer, tar etc.).
Joe
Old 06-23-2011 | 09:20 AM
Welding small holes can be very tricky, when the hole is a rust hole! I've done a little of this on fenders and most the time the little pinhole turns into a dime or nickel sized hole that requires a filler piece. If you decide to weld the holes you'll need to actually grind them, then drill the hole out until you get solid metal around it. Most pinholes need to be drilled out to at least 1/4", and sometimes 1/2".
I think I'd get a high quality rust converter and apply it to both sides of the pan after grinding it clean, then patch the tiny holes on both side with a good sealer.
Old 06-23-2011 | 12:57 PM
I would get a wire cup for that bad *** grinder I saw in one pic. Then after all was clean then take a look. For small pin holes I know what Vall is talking about oh too well. I have had good luck with a nail. Take a nail of the right size head, not galvanized, and grab it with pliers. Then tack it into the hole. Cut off the excess and grind smooth.
P.S. The same trick in a washer with the galvanizing ground off works on bigger holes, then the nail.
Old 06-23-2011 | 02:15 PM
walkingchaos's Avatar
ya the rust converter was me it worked really well. Im fiberglassing the holes in my floor.
Old 06-27-2011 | 02:12 PM
Jeepin's Avatar
Alright guys thanks I'm taking a little break from it now but will be doing some work on it in a couple weeks!
LessThanDrew
05-02-2009 07:12 PM
hurley870
12-03-2008 02:53 PM
Jackpot4
04-16-2008 08:34 PM
snake10556
01-14-2008 06:48 PM
mow_pro
05-08-2007 05:47 AM
Quick Reply: Rust!!
