Rear speakers
RE: Rear speakers
ok let me put it this way i bought some new 6x9s that dont fit in the original cut out cause the speakers are to big. i tried to put the speakers in the factory holes and it went half way down on the cut out so dont tell me i need to try again!!!!!!
RE: Rear speakers
LOL ... they don't fit because your not mounting them right. just because something has a hole doesn't mean your suppose to shove something in it LOL. you may have to drill 4 small holes to screw them to the underside of rear dash plate. can't remember what the mounting hardware looked like. sick
RE: Rear speakers
thank yall for the info. as of now i do have them mounted under the rear dash, but the actual hole is to small. the set up now is the speaker cover then you can see the rear dash then under that is the speaker. all the mounting holes are correct, but it just looks like complete crap when you can see the rear dash covering part of the speaker. my brother had the same problem on his 72 nova but he just cut the holes bigger to avoid that problem. i just didnt wanna cut it up. if yall wanna see what im talking about i will put some pictures up next time i go home.
RE: Rear speakers
ORIGINAL: 72camaro
RE: Rear speakers
sorry if i sounded snappy but the way you said it made it sound like i was a complete moron, i have read many forums on here where people do that and i aint taking that crap. but any way i wanted to mount them from the top to keep the rear dash from showing from between the speaker cover and the speaker itself but i didnt wanna cut up anything. another option would be to get some original speakers to place there, so if anyone has any, or knows where to get some that would be a big help too.
RE: Rear speakers
it's not that you were a moron or anything, it's just that I knew they were supposed to fit so I was stating some correct information for you because you didn't know that
anyway, try Year One. they have everything you need to do it correctly. I went to their website but they don't have that stuff online but I have it all here in their catalog, so just call them and they can hook you up
