Rally Dash
Has anyone swapped the dashboard in a base over to a Rally? I know there's a plug on the fire wall for tach signal. And there is aftermarket solution with Dakota. But I would really rather have the stock. Even with the probably broken clock. So I know I will have to pin in the tach but I wonder what else will have to be pined or replaced. Temp sender and oil pressure switch. And if they get power from PCB on the back. If anyone else has done this let me know.
