problem revving
Old Jun 1, 2014 | 09:45 PM
jimm418's Avatar
Default problem revving
every once in a while when touching the gas it idk what u would call it but it makes a loud pop and normaly stalls changed the timing a lil bit and its better but not perfect do i need more timing or is it the carb?
Old Jun 1, 2014 | 10:34 PM
Have you put a timing light on it yet? That's the first thing I'd do, unless you want to just keep tweaking it, and test driving. It could be timing, carb, worn timing set, valves, or even a bad vacuum advance.
When you get a light on it to check, also watch to see if it holds the mark steady. If it wanders around, the timing set or distributor is likely bad.
Old Jun 3, 2014 | 02:28 AM
jimm418's Avatar
yeah just got a timing light and gonna check the timing again here soon also have to check out my starter more it grinds right before it fires its some high torgue unit idk the name or anything
Old Jun 3, 2014 | 02:32 AM
jimm418's Avatar
its been rebuilt at one time and had a new distributor put in. also new vacuum advance. forgot to disconnect it last time we did timing so we r gonna disconnect and do a lil more tweaking hoping that helps if not gonna have a professional engine builder take a look might change carb soon to it has a truck advenger on it instead of a street which i think would be a weird thing to do to a camaro
Old Jun 3, 2014 | 08:42 AM
The truck Avenger shouldn't hurt if it is in good shape. It's just designed to increase low end response.
Old Jun 21, 2014 | 01:12 PM
jimm418's Avatar
found out the carb was way off tune and i had a guy retune it now so it runs great lays rubber all over now also got distributer rebuilt with new springs feels so great to drive
97RallySport97
Dec 28, 2011 10:35 PM
x01660
Jul 27, 2011 06:07 AM
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
ShiftyMcCan
Dec 23, 2008 11:38 PM
2lucke4u
Sep 1, 2006 09:55 PM
