Non power disc brakes
Yes! My '71 came that way from the factory. But I swapped in a booster many years later, after getting tired of the extra foot power needed to operate the manual disc brakes. If you swap in a power booster, be sure to relocate the pivot point on the brake pedal arm! GM uses two holes on the pedal for power or manual brakes, and the hole closest to the pivot point is for manual, farthest away for power.
