New parts, won't start
So after a long removal, cleaning and new installation process, my car won't start now. I pulled off the stock intake and carb and replaced it with an edelbrock 3701/1400. After finally getting everything back in, it won't start. I know the carb is getting gas, so I don't think I'm getting a spark. Can anyone give me a place to start or advice?
You may have installed the distributor 180 degrees outta whack. If you didn't turn the engine over, you shouldn't have lost your place though. Or, maybe some wires are crossed. Retrace your footsteps:
I actually used those videos to install my distributor. I just forgot to plug power into the coil. I tried to start it and it sound like the starter was grinding. I tried it a couple more times, then the motor turned over. It ran fine, I drove it down the road and back and parked. I tried to start it to see if I could start it again for work in the morning. It sounded like it was grinding again, so I took a peek at the starter. Oil was running out of the bell housing, though I couldn't tell if it was tranny fluid or engine oil. Either way, fml... What may have happened?
You might be leaking oil from the back of the intake manifold, and it's running down. You don't want to use the rubber valley gaskets that may have come with the gaskets, they can squish out and cause a leak. RTV silicone is the only thing you want to use on the ends. Permatex Ultra Copper is a good one to use.
I used RTV silicone, and I could not find the leak. I also figured out that the grinding was from my starter bolt backing itself out. I put some locktight on it, but I still havent found my mystery leak :/
Edit: Locktight got the bolts in, but it isnt starting reliably.
Did you not have an oil leak before the intake swap? Did you look real well at the back of the intake, use a mirror if you have to, to see that the oil isn't coming from there?
Funny story: I asked my wife to try to start the car while I looked at the engine. She has never seen a manual transmission, so when she started the car, she didn't push in the clutch. I have no clutch safety switch and it was in first gear. Goodbye shins.
