Need help replacing a coil on a 1978 Z28
Old Jan 16, 2012 | 08:46 PM
HeadHunterSC's Avatar
Default Need help replacing a coil on a 1978 Z28
Does anyone have a online source for directions on how to replace a coil and some of the electronic components inside the distributor cap?
Old Jan 17, 2012 | 02:06 AM
Unscrew four bolts and unplug. Reverse to install. The ignition module is remove the cap. Remove two screws unplug. I like to use dielectric grease on the bottom of the module that I reinstall.
Old Jan 17, 2012 | 09:39 AM
pfleger's Avatar
H E I upgrade is what i did to solve my coils burning out.
Old Jan 17, 2012 | 01:20 PM
The 73 and later cars should have came with HEI.
Old Jan 18, 2012 | 03:28 PM
It does have HEI. Is there a fuse for the coil or distributor?
Old Jan 18, 2012 | 03:35 PM
rydeer's Avatar
Put a test light on the wire marked "BATT" on the dist cap. You should see power with hte key on. That is your first test!
Old Jan 18, 2012 | 11:48 PM
No fuse. The pink wire that plugs into the cap is your power. If your car has a tach, there should be a green wire next to the pink. The module is plugged into the cap behind them.
Old Jan 19, 2012 | 06:02 AM
5time F's Avatar
My best guess is that you have a blown Ignition Module. Coil going bad does happen but that is like once in twenty times.
Old Jan 19, 2012 | 10:25 PM
I replaced the coil which looked very worn and the ignition module and it started right up. Thanks for the help.
rubberduck
Jul 31, 2011 08:25 PM
daleas88
Aug 19, 2009 10:03 PM
SurfnSkate
70-81 V8 Tech
Jul 30, 2009 04:03 PM
350z28
Jun 17, 2007 04:22 PM
