NEED Help, Power to Manual Brake set up
I have a 1977 Z28 drag car (low 12's), my booster is finally done. I want to convert over to manually brakes. What length rod do I need? Whats the best fit master cylinder to buy? Do I need to change some lines? Thanks for the help.
RE: NEED Help, Power to Manual Brake set up
You might want to check out Stainless Steel Brake Company and call them. They could probably tell you what you need and offer a parts list at the same time. You could also try Classic Performance Parts and see what they have to say.
