nasty engine sludge!!
Old 10-25-2011, 09:09 AM
Originally Posted by thatcamaro
ive heard that if you pour diesel fuel on it that it will take it all off. but will that hurt any of the internal parts? also how can u tell if there was a blown head gasket without running the engine?
Corrosion on the top of the affected piston, if it's set long since it happened. Also if it leaked into the crankcase the oil should have a lighter color, foamy look to it. Might even see some water particles on top of the oil if you look closely.
Diesel used to clean up an engine wont hurt anything internally. If you really don't plan to break it down and refresh this engine, then the diesel can be used and if you get it running just change the oil again after a few hundred miles.
I personally wouldn't buy a used engine not running, and not go through it to freshen it up. That's a small amount of time and money to ensure it's worth putting in your car.
JPrice
04-24-2012 01:18 PM
borjawil
03-02-2012 08:37 AM
tpetaway86
08-12-2011 01:25 AM
2000
LS Series Tech
04-01-2011 06:11 PM
warbird
11-21-2008 04:51 PM
Quick Reply: nasty engine sludge!!
