MSD 6AL wiring
MSD 6AL wiring
hey guys, i have a 1978 Camaro with an aftermarket 350 GM crate, i was wondering if anyone has a wiring diagram for an MSD 6AL, i cannot find where to hook it up for the 12v wire, thanks everyone!
Iirc you have a thick red and thick black wire that wire direct to the battery. Then you have purple and green that go to the dizzy. A yellow? that goes to the tach, and power from pink ignition wire to a thin red wire and the smaller black and the orange go to the coil.
You can also try summitracing.com when you need diagrams and stuff like that. If you know the part number you can pull the product and they'll usually have a downloadable instructions PDF up on the right side of the screen from the manufacturer. Sometimes easier to have a one stop site that has the instructions on the same place on each page.
