-   70-81 General (https://camaroforums.com/forum/70-81-general-12/)
-   -   Mixture screw missing (https://camaroforums.com/forum/70-81-general-12/mixture-screw-missing-64612/)
gfrench Sep 6, 2011 07:07 PM
Has anyone seen a Holley 4150 without the fuel mixture screws in the
rear metering block. not my carb, helping a friend.
http://gordonfrench.com/79-chevy/questions/carb1.png
77nomad Sep 6, 2011 11:10 PM
Your missing a screw and the one in the middle is either a screw hole for the choke braket or the vacuum port for the choke. If its the port it needs to be blocked. To me it looks like the braket behind the choke lever is not on correctly.( slightly tilted upward in the rear
1971BB427 Sep 7, 2011 12:22 AM
Are you saying the screws are missing, or the holes aren't even drilled and tapped? I've never seen a double pumper that didn't have metering block mixture screws.
gfrench Sep 7, 2011 09:28 AM
The holes are not drilled an taped.
I'm wondering if it has the wrong metering block on it.
77nomad Sep 7, 2011 12:41 PM
The threads will be deep. There may be a cork gasket hiding them. I would think that the fact its a "metering" block, it should have an idle mixture screw.
gfrench Sep 7, 2011 12:53 PM
It isn't my carb, it belongs to a friend in another forum.
I had him use a mirror and said he could not see any threads.
Also took one of the screws out of the front and they would not fit.
1971BB427 Sep 7, 2011 02:12 PM
Sounds like a defect. If it's a double pumper it should have a metering block, and if it has one it should have adjusting screws. On single pumpers they don't even put a metering block on the secondary bowl, regardless of whether it's a dual feed or single feed.
gfrench Sep 7, 2011 03:55 PM
It is like 30 years old, so probably not defective.
Im thinking leave it alone, until he is ready to get a new carb.
I wish it was here, I would just pull the metering block off and look at it.
1971BB427 Sep 8, 2011 09:24 AM
Even better; find an old Holley, pull the block off, and swap in another with screws.
