LS1 bolt pattern
Old Jan 14, 2012 | 12:23 PM
bad436z28's Avatar
yeah im just gonna get mine from a 96 suburban rwd it bolts right up and no need for spacers or any of that.
Old Jan 14, 2012 | 12:45 PM
Check out this controller. Should give you the best of both worlds, for just a little more than a manual valve body.
TCI Auto 302820 - TCI EZ-TCU Automatic Transmission Controllers - Overview - SummitRacing.com
Old Jan 14, 2012 | 12:52 PM
ORAMACZ's Avatar
What is a 1969 camaro worth
Old Jan 14, 2012 | 03:35 PM
Start a post in the 1st gen forum, or you wont see many answers in somebody else's post about tranny.
Old Jan 14, 2012 | 03:49 PM
Originally Posted by exlimey
The LS motors have an extra bolt at the top of the bell housing that the sbc doesn't have. From research it isn't needed. There have been many 4L60s and 80s swapped into older cars so I'm sure there's spacers or custom torque converters available. I'm debating on the same thing. I have 3.73s and would like a good OD trans for highway driving.
I think I need to do more research with hands on. The info I found on LS1 and other sites was that the LS engine had one less mounting hole for the bellhousing than the SBC and BBC., not one more. They appear to have a total of 5 with only 4 lining up with a SBC/BBC pattern.
From looking at bellhousings for sale it appeared that the LS1 had the same dowell pins, with bolts above and below the pins, then just a center bolt at top middle. The SBC and BBC have a total of 6 bolts with the same dowell pin and bolts above and below, but one more on each side.
Here's an LS1 bellhousing:
Quick Time RM-6036 Chevy LS1 Engine Richmond Style Transmission Jerico
And a SBC bellhousing:
69 Camaro SS 350 Corvette Chevelle Nova Bellhousing 327 | eBay
So what am I missing here that I can't see more than 5 mounting bolt holes for the LS1? If it's just the dowell pin and 4 bolt I wont trust them. Doesn't appear to be enough to me. Or I'll go with the earlier that matches the SBC/BBC pattern.
Old Jan 14, 2012 | 03:53 PM
bad436z28's Avatar
yeah thats a really nice controller,but think i would still need the manual valve for the track and manual shifts,
Old Jan 14, 2012 | 04:19 PM
bad436z28's Avatar
yeah val according to ls1 tech only 4 bolt holes match up,thats why i decided against the ls1 4l80e too,with the horsepower im putting out i dont trust it,easier just to use the earlier one then no spacers or custom torque converter is needed.
Old Jan 14, 2012 | 07:05 PM
Cheeks's Avatar
August 2011 ROTM
just fyi, I use a th400 on my car and I make pretty damn good power and I'm not concerned.
The 4L80 is essentially a th400 with overdrive, its a VERY strong tranny
Old Jan 15, 2012 | 12:31 AM
But, did you catch this in the description: "The multiple shift modes include a full manual mode for using bump or paddle shifters. The TCI EZ-TCU automatic transmission controllers allow for maximum electronic control over shift points, shift firmness, and shift speed".
I like the automatic/manual adjust-ability option of the controller. Not to mention, if you set it up with a manual valve body, you still need to wire a switch for the torque converter lockup. Leaving the t.c. unlocked is not an option.
I've been wanting to put a built up 700R4/4L60 in my car, but now I'm getting more convinced that the 4L80E with the controller would be the slick way to go.
Old Jan 15, 2012 | 02:00 AM
  #20
bad436z28's Avatar
yeah me tooo i really liked that controller hopefully i can find a better price on it.
