lower motor mounts
Old Mar 8, 2012 | 05:48 PM
thebandit110's Avatar
Default lower motor mounts
Strangely enough I have never replaced the lower motor mounts on a second gen camaro. so my question is.... How the heck do you get a wrench on the bolts in the frame??? the small hole is well... to small and I cannot get a wrench on it! any input would be greatly appreciated.
Old Mar 8, 2012 | 07:00 PM
mike6208's Avatar
Use a curved distributor wrench, worked perfect on mine
Old Mar 8, 2012 | 08:03 PM
Yup a dizzy wrench is easiest. When I had my motor out I dropped fishing line down the hole with a sinker on it. Then tied it to the bolt and fished it up so the nuts were facing out. Easier than trying to get the nut on from the inside.
Old Mar 14, 2012 | 05:30 PM
Hey guys . I tried a dizzy wrench today and I was not having any luck. It did not seem to be the right size. Is there any way to access them at all??? I dont want to have to pull the control arm off to do this. But even that way it does not look easy. :/
Old Mar 14, 2012 | 06:05 PM
9/16" dizzy wrench.
blackchevelless
Jul 9, 2011 08:43 AM
Denalijim
Apr 8, 2007 07:43 AM
ronglen
Sep 20, 2006 05:19 PM
street23
Dec 18, 2005 11:29 PM
