Installing U46 Option Lamp Monitoring 1969
Hello,
I am in the process of putting back together 1969 camaro rs/ss with an option U46 Lamp monitoring lamps, that mount onto the front fenders.
Question about re-installing this option would you guys happen to know for the fiber cables this lamp monitor has three cables, the center fiber goes to the parker light, which in return lights up the clear center lense.
For the other two cables I see that the one goes to the headlight plug that is where I'm not sure that cable would connect back into the lamp monitoring lamp on which side the cable would plug into, would it be the green or blue that would light it up? And for the third fiber cable I don’t see where that would connect into.
Any info appreciated,
