holley double pumper issues 78 camaro z28
Old Sep 18, 2011 | 12:48 AM
homelver2's Avatar
Question holley double pumper issues 78 camaro z28
hey guys whenever floor my car from a stop it doesnt fully accelerate it kindof sounds like its stalling. why would it do this? i thought it might be my holley but im not sure. if i push it 3/4 of the way then fully push the pedal down it accelerates normally. thanks alot guys! (im new to cars obviously)
Old Sep 18, 2011 | 01:03 AM
homelver2's Avatar
thanks alot ill be sure to check it out in the morning
Old Sep 18, 2011 | 01:44 AM
I could only think of a couple possibilities...
Too much of an initial accelerator pump shot.
Not enough of an initial accelerator pump shot.
Float bowl level too high.
Float bowl level too low.
Choke not opening up fully.
Dirty fuel filter.
Fuel pump putting out too much pressure for the needle & seat to handle.
Vacuum advance (if so equipped) not working or hooked up properly.
Mechanical advance (if so equipped) not set right.
Old Sep 18, 2011 | 08:17 AM
What engine is the double pumper on? If it's a built 350 or larger the double pumper is OK, but if it's not well built it could be too much carb, which explains why it goes OK when you give it 3/4 throttle.
Old Sep 18, 2011 | 05:27 PM
homelver2's Avatar
yeah its a 350 small
Old Sep 18, 2011 | 05:43 PM
Sounds like too much carb. A 650 vacuum secondary would be a better choice.
Javelin3o4
May 31, 2013 05:55 PM
86iroc'r
Feb 22, 2012 07:52 PM
libertyforall1776
Mid West
May 24, 2010 04:36 PM
riceeater
Nov 16, 2007 06:37 PM
