HELP!! Speedometer gear / bullet replacement
Old Aug 21, 2010 | 09:04 AM
Vet76te's Avatar
Default HELP!! Speedometer gear / bullet replacement
Well,..I think I have really screwed up.
My speedometer wasn't working and I diagnosised it to be a bad speedo gear. Today, I went to remove it. I removed the small bolt and the retaining clip, (half circle). I thought this was all that held the gear assembly in the tail.
I tugged , tapped, and pulled,..but it would not come out. I decided to put a set of pliars on it so I could "tap" the pliars to remove the plastic housing. You guessed it,...I broke the housing where the speedo cable attaches.
To make matters worse,.the gear assembly still hasn't come out.
1)- How do you remove the gear?
2)- Where can I find teh plastic part that I broke, (and what is it called)?
Thanks in advance guys,
Old Aug 21, 2010 | 09:16 AM
I take it you're talking about the speedo gear housing. I've never seen a plastic one, you sure it wasn't made of cast pot metal? Over the years, they can get all corroded and practically weld themselves into the trans. Another issue that you can have with the old worn stock ones, is with them leaking tranny fluid, even with a good o-ring.
I replaced mine with one of these steel ones, and the leaking problem was solved for good. Speedo Gear Housing
Old Aug 21, 2010 | 04:18 PM
Vet76te's Avatar
Yes,..I'm talking about the housing. It is plastic for cetain. I have found teh replacemnet part,..on eBay. However, i still can't get the originally piece out.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Aug 21, 2010 | 10:15 PM
rosky69's Avatar
Mine took some wiggling with pliers to get it out...but came out without much of a hassle. Did you get ALL of the housing out of the way?
Old Aug 21, 2010 | 11:37 PM
Ohhhhhh that, why didn't you say you had that kind? Calling it a "bullet" is a different story!
Old Aug 22, 2010 | 07:46 AM
Vet76te's Avatar
My bad on the description,..that's just what I've always heard it called.
manslaughter299
Jul 10, 2012 08:17 AM
riss1978z28
May 21, 2012 02:27 PM
Frankenstein
Nov 19, 2010 11:21 AM
62rampsidekid
82-92 V6 Tech
Jun 26, 2010 04:01 PM
kyphur
Nov 11, 2007 05:27 PM
